15 years agoSGDMA debug
Hello, I am trying to learn how to use SGDMA to transfer data to memory. First of all, I am trying to connect SGDMA TX directly to SGDMA RX and check results. You can find the source code ->here<-...
15 years agoSocrates,
Thank you for your reply. I could almost get it to work, except the speed is too slow for SDRAM, and content copied is wrong. Could you answer some of my questions and doubts in http://www.alteraforum.com/forum/showthread.php?t=31915 ? There is not much people that knows well about SGDMA based on all the other threads i found in this forum. I found mostly BadOmen and you that talked about SGDMA here. Thank you. Regards, Michael
