15 years agoSGDMA debug
Hello, I am trying to learn how to use SGDMA to transfer data to memory. First of all, I am trying to connect SGDMA TX directly to SGDMA RX and check results. You can find the source code ->here<-...
15 years ago --- Quote Start --- Could you let me see your code? i really need to look at the final version(should be the 4th version according to the thread) of your code in order to understand what you guys were trying to say in all your previous post on this thread. --- Quote End --- Unfortunately no, I can't. You can take SGDMA example file and do a few simple modifications as described in my posts. --- Quote Start --- How do you look into the memory? --- Quote End --- In Quartus II: Tools -> In-System Memory Content Editor Remember to enable In-System Memory Content Editor in On-Chip memory options: go to SOPC, right click on on-chip memory -> Edit..., then tick "Enable In-System Memory Content Editor feature" and set a desired instance ID.
