15 years agoSGDMA debug
Hello, I am trying to learn how to use SGDMA to transfer data to memory. First of all, I am trying to connect SGDMA TX directly to SGDMA RX and check results. You can find the source code ->here<-...
15 years ago --- Quote Start --- Hello, point the current descriptor also as a next descriptor, so it would run around and do the same work. --- Quote End --- Thank you for your quick reply. Could you let me see your code? i really need to look at the final version(should be the 4th version according to the thread) of your code in order to understand what you guys were trying to say in all your previous post on this thread.:) Michael
