14 years agoSet properties of VHDL package file from component TCL file
Hello, is it possible to change a value in a VHDL package file from a component TCL script? I have a component which is parameterized by a constant value which is set in a package: p...
14 years agoWould the script then modify the code? The best solution for me would be that it overrides the value given in the package for the generation of the system but it shouldn't touch the file.
If this is not possible I would be interested in your solution which modifies the constant. Do you have an example on how to do that?
