14 years agoSet PATH during uClinux kernel boot
I'm running uClinux on the DE2 board. I've added detail in my design to include an SD card. I mount the SD card in the rc file. This allows me to easily add user files the the uClinux file system....
14 years agoWhat is your shell?
For bash, the files .bashrc or .bash_profile (something like that) get sourced at startup, so you can put export PATH=$PATH:/mnt/sd/bin in that file. Or you can first check if /mnt/sd/bin exists ... if [ -e /mnt/sd/bin ]; then export PATH=$PATH:/mnt/sd/bin fi; (No guarantees that this is valid bash code, you can Google for the correct syntax) Cheers, Dave
