Ftiglius
7 years agoSelf-bootable Nios Ssytem (boot copier). How to calculate SOF image size?
I'm following guidelines from https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/edh_ed_handbook.pdf to obtain a self-bootable FPGA SOC with NiosII, 64 Mb ecpq flash a...
APaci1
7 years agoYHes I and AApacione working on same group. The main issue was solved from Jumaah, he changed ECPQ controller from type II to standard one, reducing speed downto 25 Mhz. This is the main issue. We have found that ECPQ II type controller DOESNT' WORK with ECPQA64 Flash, probably intel should investigate to this issue and clarifiy it. We lost a bunch of time attempting to boot our system, we cannot think about a ECPQII original controller had problems. I confirm that ECPQ controller standard works fine on both single and quad settings, using standard MSEL pin setting I have tested it on two our PCB... results are ok on both. Boot runs correctly with MSEL standard and QUAD ECPQ controller standard set to 25 Mhz. !!
