12 years agoSDRAM signals managing
Hi, I'm using qsys to implement a system on Quartus II. I use a DE0-NANO board and I want to access the SDRAM. I want to access it from a Nios II (and also from the hardware design but it's anot...
12 years ago --- Quote Start --- I have three new questions: 1-How to make the SDRAM available both for the software part (a Nios II cpu in a Qsys system) and the hardware part (a Quartus II design)? --- Quote End --- The hardware that needs to access the SDRAM needs to be written as an Avalon-MM master, so that it can initiate SDRAM reads or writes. Alternatively, your hardware can be an Avalon-MM slave or Avalon-ST sink/source, and you can use a DMA controller to move data from your component to/from SDRAM. --- Quote Start --- 2-How to tell Qsys that the program of the cpu should be stored in the internal FPGA memory and the data should be stored in the SDRAM? --- Quote End --- That is not a Qsys task. That is the job of the linker script. --- Quote Start --- 3-I've downloaded this file: http://www.altera.com/products/ip/altera/ocore_sdr_sdram.html and a first problem is the address bus width. In the file it's 12-bit but in the first qsys system it was 13-bit. --- Quote End --- You already have a working SDRAM controller (using the standard Altera Avalon-MM SDRAM controller), why are you trying to use this design? Cheers, Dave
