14 years agoSDR SDRAM memory tests
Hello, I've designed a board, with 5 separate SDR SDRAM chips, now I've got the PCBs and trying to test the memory reads/writes. 3 of the chips are working fine, however two of them behaves strang...
14 years agoThe first thing I can think of is the same as what the first part of the console output states:
are you sure you have mapped every Nios memory sections into onchip ram? I mean code, data, but also stack, exception/reset vectors and possibly other sections.
