9 years agosave the values from nios 2 console
hi hi,i am able to print a set of values to nios 2 consolehttp://www.edaboard.com/attachment.php?attachmentid=140600&d=1502960114&thumb=1 (http://www.edaboard.com/attachment.php?attachmentid=1406...
9 years agoIf you want to copy from the Nios II Console and then past to a text editor , you can try this to see if it works...
save printf output from nios ii console: • Currently using Eclipse from Quartus Prime 17.0. Not sure if this works in other versions. • I have not found this documented anywhere, just found it by trial and error. • Prior to clicking the run button, kill the Nios II Console window if it is open. It will re-open when it starts running. • During/after run has executed, select text in Nios II Console window. • Select Ctrl-Insert key combination. It should now be copied to the clipboard. • Paste with Ctrl-v. • This only seems to work once. Must kill window and re-run to do another copy/paste.
