21 years agoRunning program in SDRAM
Dear all,
I just solided on FPGA board with Cyclone and SDRAM. I tried the example Hello_World_Small program in on_chip_ram, and received the output via UART. Then I add the SDRAM Controller (with the parameters described in SDRAM datasheet) and connect the corresponding signal to SDRAM Chip, recompile the system, set the rest point to SDRAM in SOPC Builder. Also in the NIOS IDE, I set the Program running in SDRAM. What I got is: Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Pausing target processor: OK Downloading 00800000 ( 0%) Downloaded 6KB in 0.1s Verifying 00800000 ( 0%) Verify failed Leaving target processor paused 00800000 is my SDRAM Address. What may cause such problem? Thanks!1 Reply
redsun,
> What may cause such problem? There are many potential causes. Here are some: - SDRAM was not placed correctly (shorts/opens on pads). - Bad traces between Cyclone and SDRAM. - SDRAM clock doesn't meet timing requirements. - Pins are not assigned correctly. - SDRAM timing parameters are incorrect. - SDRAM is not actually mapped to 0080_0000. Check the easy stuff first (pin assignment, timing parms, base addrs) first. The check your timing analyzer results against your board layout -- you may need to shift your SDRAM clock phase. Finally, break out a scope and add an SDRAM memory test to your hello_world that runs out of on chip ram Make sure you bypass/don't implement the data cache. Regards, --Scott
