15 years agoRunning from external SSRAM issues
Hi, I am using custom board along with Arria II GX Fpga.I am trying to run nios program on external SSRAM (Cypress-compatible memory).The problem began recently.as i have experienced a short-circuit...
15 years agoThat what is probably happening.But this does not happen while running on internal RAM.There is got to be some hardware issue with the SSRAM (and/or its SOPC component),i just can't figure out what it is and how to fix it :).
I also want to point out that I haven't had any issue with the memory prior to short-circuit.
