9 years agoRunning a C code without uploading Linux to DE1-SoC
Hello. I want to run a C code in DE1-SoC. I've been searching online and it seems that the only way it's possible is downloading Linux to the board. Is there any way to access the ARM and run the cod...
9 years agoThe keyword you need to search for is "baremetal". This is the environment where you program directly a C code app without Linux.
You will need however to program the preloader and use ARM DS-5 for writing the C code. A good tutorial with the different steps to run baremetal C code in a Cyclone V SoC can be found below: https://rocketboards.org/foswiki/view/documentation/ws1introtoalterasocdevices
