15 years agoRS232 coding problem
Hi all, I require to send/receive a character through the rs232 port, however i only be able to receive character. I had problem with sending the character out. Below is my coding for sending a...
15 years agohow about doubting VB.
in some case you can not get characters when the character is not correct ASCII code. you should measure the signal TX. by oscilloscope or signaltapII. or, just send UART signal from NiosII to "the NiosII" by itself. good luck.
