12 years agoResource Collisions when installing PCIe DD
Does anyone know what this could mean ? Jan 1 00:30:22 linaro-developer kernel: [ 1822.434579] PCI: Device 0000:01:00.0 not available because of resource collisions I have the sample SG ...
12 years agoThanks Dave,
I did reduce the BAR sizes to 1MB without changing anything and there was a dmesg line that indicated the same but at the end the resource collision message was still the result. The system is an ARM 32 bit system ... I traced the kernel source back to a resource allocation section which I believe must be responsible for setting the resource->start and resource->end values. ... later on in mach-msm the pcie.c code run through a 0 .. 6 for loop examining the start and end values for each resource. The fail is where the start value is 0 which I am able to see via a printk. The indx vale in the for loop was 0 ... and I interpreted that at the BAR0 resource but may be mistaken. Currently I have reduced to a single BAR0 (32bit address ) and I did notice there are some requirements checked before the resource allocation code does it's job ... like checks for if pre-fetching is allowed or not ... I need to check on ARM where this decision is made. in /proc/mem I do see space allocated for the memory beyond the PCIe bridge ( Synopsys IP ) The original reference design has BAR0/1 as pre-fetchable and BAR2 not ... I guess this is since BAR2 handles NIOSII IP where pre-fetching could have side-effects that we can't handle. So I will run with and without pre-fetching on BAR0 and see what happens . BTW, 1BM isn't mach menory per BAR. The system memory map allocates 128MB of space for PCI ... That seems a fair bit for the BAR's and possibly ROM ... but I ca see that 4GB is too large and the dmesg output indicate that. Best Regards, Bob
