20 years agoReset only the CPU
I have a system with a custom peripheral, a CPU and a dual ported memory which is connected to the PC via PCI interface. The CPU runns from the software stored in the dualported RAM. Now I want...
20 years agoHi Klaus and Fischer,
I've struggled with many of the same issues ... and all related to PCI. In my case however, the PCI bridge (configured as an adapter) implemented bus mastering. Needless to say, I had many of those "locked up" moments -- mostly because there isn't an independent "CPU reset" vs. a System Module reset 8-P Anyway, the watchdog approach was reliable ... a bit slow ... but reliable. If you have an instruction cache and you place that busy loop in a single line, you can spin without any bus activity. Regards, --Scott
