15 years agoRequired Nios components
Hello, I am trying to develop a very simple Nios cpu to run Hello world application. I have created a design: http://i55.tinypic.com/a29isy.jpg As You can see, I have inserted DDR2 memory ...
15 years ago --- Quote Start --- Yes. Connect all the system peripherals through pipeline bridge (e.g. sysid, jtag, timers, etc). Also fix timing warnings. It is possible to run Nios II @ 133MHz on Cyclone speed grade 8 and ~160MHz on the fastest speed grade. Maybe more, but I've not tested that. --- Quote End --- Thanks for the suggestion Socrates. I am really hopefull that this will get me out of the rut that I have been in for the past several days. However, now I am back to the old problem that keeps showing up whereby the System ID and Timestamp cannot be found. The system is running at a conservative 50 MHz and Timequest is not complaining about not meeting constraints. I tried with the Sys_ID component inside and outside the pipeline bridge, but neither work. It was working before I added the pipeline bridge to the Qsys design. I attached a screen shot of my Qsys design as it stands now.
