15 years agoRequired Nios components
Hello, I am trying to develop a very simple Nios cpu to run Hello world application. I have created a design: http://i55.tinypic.com/a29isy.jpg As You can see, I have inserted DDR2 memory ...
15 years ago --- Quote Start --- I have replaced the DDR2 memory with on-chip memory (262144 bytes), but the issue somehow was 125MHz clock. I have set the 50MHz clock instead and the Nios started. The 125MHz clock was running for sure, I have made a blinker which works either with 125MHz clock or with 50MHz clock. The development board is Cyclone III Host board from Altera (2 clocks on board + SMA IN) Now the strange problem is that the console doesn't show anything. It runs the CPU: I've checked BSP parameters, the stdin/stdout/stderr are all set to uart_jtag, but the console screen is empty. --- Quote End --- I know this was quite a while ago, Socrates, but I'm having this same problem now. I'm wondering if you were able to solve this issue of no output on the Nios Console.
