15 years agoRequired Nios components
Hello, I am trying to develop a very simple Nios cpu to run Hello world application. I have created a design: http://i55.tinypic.com/a29isy.jpg As You can see, I have inserted DDR2 memory ...
15 years agoThe data cache will mask those problems because it will always do 32-bit accesses. Without the cache (or if you do an access by bypassing the cache) all 8-bit writes will fail. I guess that 8-bit accesses can happen in I/O functions, but also possibly in all string-manipulating functions, so it could be a problem.
According to this message by dsl (http://www.alteraforum.com/forum/showpost.php?p=123683&postcount=4), you will also run into problems with 16-bit accesses if you don't connect the byte enable lines, so you should keep the data cache for now, and avoid any cache bypassing.
