15 years agoRequired Nios components
Hello, I am trying to develop a very simple Nios cpu to run Hello world application. I have created a design: http://i55.tinypic.com/a29isy.jpg As You can see, I have inserted DDR2 memory ...
15 years ago --- Quote Start --- I can't actually imagine that the cpu would run well enough to execute the memory test code at all if the memory was generating errors like those shown. --- Quote End --- The CPU only uses 32-bit reads to load the code, doesn't it? If there were a problem with byte enables as I suggested, it would mostly show up during I/O, but probably not before...
