15 years agoRequired Nios components
Hello, I am trying to develop a very simple Nios cpu to run Hello world application. I have created a design: http://i55.tinypic.com/a29isy.jpg As You can see, I have inserted DDR2 memory ...
15 years agoYou need to constrain tck to run at at least 10MHz if you're using timequest (20MHz if you use the old timing analyser). The On-board USB-Blaster in the neek runs tck at upto 8MHz.
Also, there is probably little benefit to running the Avalon clock for the JTAG UART so slowly - I would run that at 20MHz or more (and check it meets timing)
