15 years agoRequired Nios components
Hello, I am trying to develop a very simple Nios cpu to run Hello world application. I have created a design: http://i55.tinypic.com/a29isy.jpg As You can see, I have inserted DDR2 memory ...
15 years agoThanks for all the great suggestions.
I constrained the design and ran a timing analysis which is fine. I changed the JTAG UART clock to 5 MHZ with the Nios II CPU running at 50 MHZ and a clock crossing bridge between them. I also tried a pipeline bridge in series with the JTAG UART. None of this made any change whatsoever to the corrupted text I'm getting on the Nios II Console. I tested a similar Qsys design on the Altera Cyclone III Nios II NEEK and it runs fine - uh oh, something must be wrong with my board!!! Here's the text I get on the NEEK: <----> Nios II Memory Test. <----> This software example tests the memory in your system to assure it is working properly. This test is destructive to the contents of the memory it tests. Assure the memory being tested does not contain the executable or data sections of this code or the exception address of the system. And this is what I get on my board running the same Memory Test app: <<---- iissII eeooyyTTss.. <<----> hhssssffwwrr xxmmll eett hh eeooyyii oorrssssee ooaassrr ttii ookknn rrpprryy TTii eettii eettuuttvv ootteeccnneett fftteemmmmrr ttttssss ssuueetteemmmmrr eenn eettddddee oo oottii the executable or data sections of this code or the exception addres fftteessssee..
