15 years agoRequired Nios components
Hello, I am trying to develop a very simple Nios cpu to run Hello world application. I have created a design: http://i55.tinypic.com/a29isy.jpg As You can see, I have inserted DDR2 memory ...
15 years agoI'm not sure your problem is related to that. Does the problem disappear with a lower frequency? Did you run a timing analysis on your system? You should only add pipelines if your design doesn't meet timing requirements.
