15 years agoRequired Nios components
Hello, I am trying to develop a very simple Nios cpu to run Hello world application. I have created a design: http://i55.tinypic.com/a29isy.jpg As You can see, I have inserted DDR2 memory ...
15 years ago --- Quote Start --- and dont forget conect the data slave and data master.......... --- Quote End --- I'm not sure I understand. Do I use one pipeline_bridge and connect its s0 to both the cpu data_master and instruction_master, then connect the pipeline_bridge m0 to the jtag_debug_module? Or... Should I use two pipe_line bridge instances - one for the data_master and one for the instruction_master?
