15 years agoRequired Nios components
Hello, I am trying to develop a very simple Nios cpu to run Hello world application. I have created a design: http://i55.tinypic.com/a29isy.jpg As You can see, I have inserted DDR2 memory ...
15 years agoProbably You're right. I have set the ddr controller to run at half rate (125MHz/2=62.5MHz), doubled the burst and now Nios runs fine, no need of pipeline bridge.
Thanks for help... Time to test SGDMA! Or maybe modular sgdma is better? Still confused, I need to transfer coded video data in packets to Nios, add IP header and proceed to TSE :)
