NZami
7 years agoremote update IP with cyclone10 LP
Hi, I used the remote update core to load 2 images (factory and application) with cyclone III work with Active parallel mode. Now I try to load the 2 images to cyclone10 LP. I work now at Active Ser...
Nooraini_Y_Intel
7 years agoHi NZami,
I further checked, it seems for newer Quartus version in the remote update IP, you don't need to truncate 2 LSB of the start address. This should be taken care by the remote update IP. For active serial devices using the 24-bit addressing, such as EPCS128/EPCQ128 and lower density, the boot_address[23..2] corresponds to the upper 22 bits of the 24-bits boot address while the boot_address[1..0] is read as 2'b0. Thus you can set the application image start address value 0x200000 to data_in[23..0] of the remote update IP.
Nooraini
