NZami
7 years agoremote update IP with cyclone10 LP
Hi, I used the remote update core to load 2 images (factory and application) with cyclone III work with Active parallel mode. Now I try to load the 2 images to cyclone10 LP. I work now at Active Ser...
Nooraini_Y_Intel
7 years agoHi NZami,
It was a typo error. In the Convert Programming File utilities, when setting the Application image start address, you need to set to 0x200000h.
I suggest that you can look into the existing example design which should provide the information that you need.
Nooraini
