hjian6's avatar
hjian6
8 years ago
Remote system upgrade issue
The follow picture is my current 10m16’s compilation report, my issues are as follows:
  1. I would like to add new function to realize remote system upgrade (RSU). I’m not sure 10m16 resource is enough if it set up NIOS II architecture with necessary modules.
  2. My current FPGA (10m16) circuit, specific pins like NCONFIG, CONF_DONE and BOOT_SEL have been pull up to VCC, whether will it impact remote system upgrade function I want?
  3. In the condition of current circuit, can I use NIOS II or self-build modules to realize RSU function to receive new profile through serial interface and do reconfiguration, then run new program without repowering FPGA?
  4. If it must set up NIOS II, I would like to save it into UFM and run it into RAM, could it be realize?
Related folder I found on intel net may be not latest, so please afford them to me if you have. If you have related example, may be I will catch and realize the function quickly.
Thanks in advance.
