20 years ago
regarding the downloading the design in Flash
This is prasad from CRL_BEL
This is regarding the downloading the design in Flash
and running the nios processor
In sopc builder i have set the reset address to be in flash
offset is 0x00000000 and address is 0x01000020 in sopc builder in nios II more CPU settings
base and end address in system contents is 0x01000000 to 0x01ffffff
and now i have generated the system.
in system library properties of the test program i have set the following
program memory flash
read only memory flash
r/w memory sdram
heap memory and stack memory sdram
and i am programming it using flash programmer
in my application code i have written only printf statements
through jtag usb blaster
but nothing is working upon reset or reset configuration
whereas downloading in flash is done properly.
can anybody help me in this ?
thanks in advance
prasad
CRL_BEL
    Are you using a Nios development board by any chance? If so make sure that under the Quartus II device options that "Unused I/O" is not set to ground (that would cause the board to re-config after programming if the reconfig_n signal isn't hooked up).
    Also are you sure you want to be using these settings?
    "program memory flash
    read only memory flash"
    That's not going to get you very good performance since the Nios instruction and data masters must access the program/read only data sections.
    Actually i have set that all the unused pins be assigned as input tri-stated
    so i don't think the eproblem u said may arise.
    also will there be any problem if i say
    that i want to have the program memory in flash and rom memory in flash.
    anyway i have set the r/w memory in sdram.
    but nothing is working.no response from the system at all after downloading
    both sof and the application in flash using the flash programmer.
    any more suggestions???
    thanks in advance
    prasad
    Hi prasad,
    What board are you using?
    Are you using the hal or are you using custom code?
    What does this mean? The FPGA does not complete configuration? Your initialization code does not
    run? You don't see the output of your printf statements?
    Are you using a serial port/uart or the jtag uart?
    Use nios2-console. Reset the cpu, check your startup code at the reset address, test your memory,
    and try single stepping, set a hardware breakpoint at main(), etc. Then let us know what you
    observe.
    --Scott
    Hi Scott,
    Thanks for the response.
    actually i am using the nios development kit
    also i am using HAL libraries only.
    i am able to downlaod the design(application + sof)
    through the flash programmer .
    but when i reset the processor no response.
    i am using the jtag uart(usb) as my std err and std output.
    when i reset the configuration, corrresponding configuration led is glowing
    and configuring the fpga.
    but no response.
    also in the earlier replies i have given my reset address and other setting of the system library.
    please suggest to me how to rectify the problem.
    i have set 2 conditions
    in sopc
    1) reset address in flash offset 0x00000000 and address 0x01000000
    2) exception address in flash offest 0x00000020 and address 0x01000020
    in nios system library properties
    a) http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif c)
    program memory -- flash program memory -- sdram program memory -- sram
    rom memory -- flash rom memory -- sdram rom memory -- sram
    r/w memory -- sdram r/w memory -- sram r/w memory -- sram
    for any of the combinations above it is not working i.e. no response if i reset the processor
    but dowloading in flash and configuring the fpga from flash when reseted is happening
    also i want to confirm is pll mandatory for the above conditions? ie. for sdram and sram?
    i did not use pll in the design.
    but atleast soem things should come right?
    anyway suggest me on this
    thanks
    prasad
    Hi prasad,
    > but no response.
    I did ... in my last post. Did you try any of those suggestions?
    Regardless, when the sum total of your observations is "no response" ... it&#39;s time to keep
    things simple and take smaller steps. Forget about programming flash and starting your app
    at power-on. Get it working first ... then worry about the fancy stuff later:
    1. Change your exception address to sdram.
    2. Re-build your system.
    3. Load your design via jtag (using Quartus Programmer for example).
    4. Change your system library properties to put everything in SRAM.
    5. Rebuild your application.
    6. Start debugging -- by downloading your app to SRAM.
    If you still get "no response" it&#39;s probably time to look at your logic design.
    /o Before you do anything else ... do yourself a favor and review the example designs
    for your particular development kit ... then add the pll to your design.
    --Scott
    Sorry, my bad:
    - 1. Change your exception address to sdram.
    - 1. Change your exception address to SRAM.
    --Scott
    Hi prasad,
    > can&#39;t i have my exception address in flash?
    Yes, of course.
    > what will be the implications?
    You will not be able to change code at the exception address -- which may be just fine for
    your application. There are some situations where you may need to change/overwrite the
    code at the exception address however ... using u-boot to load the linux kernel for example.
    But this all depends on your requirements.
    --Scott
    Hi Scott
    actually how much of memory will be consumed for
    boot code in flash that will be added by nios IDE in front of the application code.
    i think it is just 0x20 bytes. am i wrong
    thanks and bye
    prasad
