15 years agoRegarding Hello World Template
hi this is sundaram from University of Waterloo. I'm current having a problem with the hello world template. I have been working on the FPGA for some months and it has always worked as expected. Howe...
14 years agoHi sundargates,
Did you ever find a solution to this problem? I'm running into the same issue. I'm running out of an on-chip memory of 131072 bytes which should be large enough. I also ran the small hello world and that worked fine. It looks like I have a problem with my interrupts but they appear to be hooked up correctly. Thanks, Scott
