Julien
8 years agoReference example for NIOS writing to HPS's DDR3 on CycloneV SoC ?
Hi, I am looking for a reference example, ideally for the DE0-Nano SoC (but any CycloneV SoC based example will do), that would allow me to test the following configuration: a NIOS2 implemented in ...
Ahmed_H_Intel1
7 years agoHi,
You have some errors in your connections, first, to access the DDR3 you must connect the span extender to F2H_sdram_data. I've tried to connect the system you need with no errors as show in the image below.
Also you can see the address span extender setting and the HPS setting
I will attach a design example tested already for the DE10_Nano (CV)
