14 years agoRebuild OpenCV libraries in NIOS II (8.0)
:confused: Hello I want make a video tracking project on NIOS II. My project can be successfully built in Eclipse(with CDT) after some configuration work( include path, librar...
14 years ago --- Quote Start --- You are missing more system headers. Probably string.h and sys/time.h It is also worth always using the unix '/' in directory paths, rather than the microsoft '\'. The former is valid in almost all microsoft tools. --- Quote End --- After making some change in the original project, I finally passed the compile phase, but when linking, there are errors said the opencv libraries can not be found. So I think the problem still lies in the incompatibility between nios2-elf-gcc compiled files and the gcc on my computer system(mine is Ubuntu 11.10) So I think I still need to recompile the opencv libraries by nios2-elf-gcc.
