14 years agoRebuild OpenCV libraries in NIOS II (8.0)
:confused: Hello I want make a video tracking project on NIOS II. My project can be successfully built in Eclipse(with CDT) after some configuration work( include path, librar...
14 years ago --- Quote Start --- No this is all about header files and the build environment, not the IDE. Your 'working' build is (if I understand you) targetted at a completely different environment. You need stdint.h from somewhere. --- Quote End --- dsl, I found you're right about the stdint.h thing. I add "\usr\include\" in the include path, and add# include <stdint.h> in the cpp file. Then errors about "int64" disappeared, but new errors come, shown as follows:
Severity and Description Path Resource Location Creation Time Id
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/char_traits.h error: initializing argument 1 of `void* std::memchr(void*, int, size_t)' hello_world_opencv line 262 1331094172861 1533
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/char_traits.h error: `memcmp' was not declared in this scope hello_world_opencv line 254 1331094172859 1530
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/char_traits.h error: `memcpy' was not declared in this scope hello_world_opencv line 270 1331094172863 1535
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/char_traits.h error: `memmove' is not a member of `std' hello_world_opencv line 186 1331094172858 1529
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/char_traits.h error: `memmove' was not declared in this scope hello_world_opencv line 266 1331094172862 1534
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/char_traits.h error: `memset' was not declared in this scope hello_world_opencv line 274 1331094172864 1536
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/char_traits.h error: `strlen' was not declared in this scope hello_world_opencv line 258 1331094172860 1531
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/char_traits.h error: invalid conversion from `const void*' to `void*' hello_world_opencv line 262 1331094172861 1532
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/codecvt.h error: `strcmp' is not a member of `std' hello_world_opencv line 460 1331094172893 1567
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_classes.h error: `strcmp' is not a member of `std' hello_world_opencv line 538 1331094172871 1537
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_classes.h error: `strcpy' is not a member of `std' hello_world_opencv line 579 1331094172872 1538
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.h error: `memcmp' was not declared in this scope hello_world_opencv line 1167 1331094172889 1565
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.h error: `memcmp' was not declared in this scope hello_world_opencv line 1182 1331094172892 1566
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.h error: `memcpy' was not declared in this scope hello_world_opencv line 897 1331094172887 1561
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.h error: `memcpy' was not declared in this scope hello_world_opencv line 962 1331094172888 1562
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.h error: `memcpy' was not declared in this scope hello_world_opencv line 1099 1331094172888 1563
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.h error: `memcpy' was not declared in this scope hello_world_opencv line 1152 1331094172889 1564
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.h error: `strcmp' is not a member of `std' hello_world_opencv line 1898 1331094172895 1568
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.h error: `strcmp' is not a member of `std' hello_world_opencv line 2653 1331094172897 1569
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.h error: `strcmp' is not a member of `std' hello_world_opencv line 3932 1331094172901 1572
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.tcc error: invalid use of undefined type `struct tm' hello_world_opencv line 1749 1331094172905 1574
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.tcc error: invalid use of undefined type `struct tm' hello_world_opencv line 1756 1331094172908 1576
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.tcc error: invalid use of undefined type `struct tm' hello_world_opencv line 1764 1331094172910 1577
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.tcc error: invalid use of undefined type `struct tm' hello_world_opencv line 1771 1331094172911 1578
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.tcc error: invalid use of undefined type `struct tm' hello_world_opencv line 1783 1331094172912 1579
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.tcc error: invalid use of undefined type `struct tm' hello_world_opencv line 1790 1331094172913 1580
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.tcc error: invalid use of undefined type `struct tm' hello_world_opencv line 1793 1331094172913 1581
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.tcc error: invalid use of undefined type `struct tm' hello_world_opencv line 1805 1331094172915 1582
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.tcc error: invalid use of undefined type `struct tm' hello_world_opencv line 1810 1331094172917 1583
/opt/altera8.0/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/../lib/gcc/nios2-elf/3.4.6/../../../../../include/c++/3.4.6/bits/locale_facets.tcc error: invalid use of undefined type `struct tm' hello_world_opencv line 1818 1331094172918 1584
Can you explain these errors? thanks Yang
