14 years agoReading Input Pin
Hi, I want to read a signal from a PIN. Everything ist fine I built it up in the SOPC Builder and declare a 8bit for Input. I chose 8Pins in Quartus and everything wotks fine. I can write O...
14 years agoYou are right.I did everything right but the only problem is I did`t put them on Ground. Now it works thx a lot Daixiwen. (http://www.alteraforum.com/forum/member.php?find=lastposter&t=35770)
Problem solved!
