14 years agoReading Input Pin
Hi, I want to read a signal from a PIN. Everything ist fine I built it up in the SOPC Builder and declare a 8bit for Input. I chose 8Pins in Quartus and everything wotks fine. I can write O...
14 years agoIT looks like you are doing everything right. Using signaltap you can check the actual value of the 8-bti signal that you provide to the PIO, and verify that it is the value you set the pins to.
