14 years agoReading FPGA config & Application from EPCS
Hi, Bit of a noob here regarding embedded development, so go easy. I've been developing some firmware for a device using the NIOS II processor and the device is set up to configure and boo...
14 years agoI also think enough of the format of the EPCS image is documented to let you read it to find the code to download - and hence the end of it.
If you want to save other info in the latter blocks, I'd pick a fixed offset that gives some free space beyond the current used part - that way you won't get into trouble when the fpga image grows!
