14 years agoRead access through Avalon-MM tristate bridge
Hi there, I was simulating an external memory access through Avalon-MM tristate bridge and the data width of my external memory is 16 bits. Everything worked fine except that, it always perform...
14 years agoAs well as behaviour of the bus width adapter (which might do cycles with no asserted byte enables), the nios2 processor always asserts all 4 byte enables for its memory reads - regardless of the requested width.
