niosv-download download prompts the same error
After the Riscfree download error occurred, we also tried other methods to start the niosv platform, that is, the 5.5.2. Niosv Processor application execute-In-Place from UFM described in the manual. This can solve the situation where the elf is larger than the available RAM, and when the elf changes, you only need to regenerate the pof.
However, after strictly following the hardware and software design procedures in 5.5.2.1 and 5.5.2.2, the Niosv serial output still has problems. Using Signal Tap to capture the niosv data_manager bus, we found that wvalid and rvalid were never pulled high.
Hi zjyoof
For the error seen that could not halt.
Try reducing the jtag frequency with the command and try again:
jtagconfig --setparam <cable number> JtagClock <frequency><unit prefix>
