prashant_gohel
1 year agoNIOSV firmware stuck when juart-terminal is not open for the print messasges.
Hi, I am facing an issue where the NIOSV firmware gets stuck if the JUART terminal is not open for printing messages. Once I open the JUART terminal, everything works fine. Is there any way or BSP ...
EstebanV_Altera
1 year agoHello,
This is not usual behavior, the default shouldn't behave like this. Are you having prints into the terminal? If you remove such prints the programs continues?
Which Quartus version are you using? Which NIOSV version (G,C,M)?
Please provide as much details as possible so I can reproduce
~E.V.
- prashant_gohel1 year ago
Hi Esteban,
I am using Quartus 25.1 with NIOSV version M.
When the terminal is open, everything works fine, but if I close the terminal, the NIOSV gets stuck. Our requirement is that the NIOSV should run normally without needing the terminal to be open.
