9 years agoQuestions about SOC FPGA Preloader and device tree
Hi I’m working on a project using the Terasic Spider robot which uses the DE0 NANO SOC board. It is a Cyclone 5 board. I’m building a Metal Detection application on top of the spider and I’m ...
9 years agoproblem solved:
In order to load an FPGA sof file, we need to generate an rbf file first (note this can be done from the GUI): quartus_cpf -c <input file>.sof <output file>.rbf Copy the .rbf file to the FAT partition of the SD card Then, from u-boot: set fpgaload "fatload mmc 0:1 0x2000000 fpga.rbf;fpga load 0 $""{fpgadata} $""{filesize}" set bootcmd "run mmcload;run fpgaload;run mmcboot" run bootcmd You may automate this by doing an: env save If there is no message your fpga should be programmed, check the config LED. If it fails with a -4 return code it has failed, most probably due to the data format. Check the MSEL switch settings and make sure they match the rbf format (up-up-down-up-up-up = uncompressed rbf) Enjoy! https://rocketboards.org/foswiki/documentation/loadingfpgafromuboot
