9 years agoQuestions about SOC FPGA Preloader and device tree
Hi I’m working on a project using the Terasic Spider robot which uses the DE0 NANO SOC board. It is a Cyclone 5 board. I’m building a Metal Detection application on top of the spider and I’m ...
9 years agoHi, thanks but perhaps my problem is different. I post it here de1-soc problem with tree please help!! (https://www.alteraforum.com/forum/showthread.php?t=56009)
--- Quote Start --- Yes, i had to solve it because it was my senior project. The problem was when you compile the Quartus project and generate header file (HPS_0.h) i found out that it has some problems in the memory addresses of some of the components(some of the component has wider address space than the references design) therefore, instead of using the generated one, i modified the original HPS_0.h from the reference design(comes with the c++ program that you download from the website). i just copied the ADC component from the generated to the original and everything worked together just fine. you do not need to change the dtb. However, the rbf should be changed with the generated from the compilation. if you need more help contact me. --- Quote End --- or maybe yo are right. I can edit dts but there are some problems with the sistema.sopcinfo so:Component alt_vip_itc_0 of class alt_vip_itc is unknownComponent alt_vip_itc_0 of class alt_vip_itc is unknown
Component pll_0 of class altera_pll is unknown
Component pll_6553600 of class altera_pll is unknown
Component reset_controller_0 of class altera_reset_controller is unknown
Component reset_controller_1 of class altera_reset_controller is unknown
Component video_pll_0 of class altera_up_avalon_video_pll is unknown
MasterIF sopc2dts.lib.components.Interface@76fb509a slaveIF null
