15 years agoQuestion on Git Branches to use [nios2mmu vs unstable-nios2mmu]
Hi everyone I'm currenlty looking into using Linux on the NIOS for my company. Will be getting a DE4 from Terassic shortly but in the meantime I'm doing all the prepwork to understand as much a...
15 years agoHi,
Thank you for your responses, it works with that. I have another question. I try to use the unstable_nios2mmu branch for linux2.6 and trunk for uClinuxdist in order to use the dts (device tree) support. I try to follow the Altera Wiki (alterawiki.com/wiki/Devicetree) but it's said : //////////////////////////////////////////////////////////////////////////////////// 5) enable device tree support in your uClinux-dist kernel config. enter the full path to your dts file in (), which will be dtc compiled and the dtb is linked into the kernel. important: You may still need to edit the file linux-2.6/arch/nios2/boards/generic-dts/include/asm/nios.h, to match your memory and cpu info. //////////////////////////////////////////////////////////////////////////////////// In the unstable_nios2mmu branch I find any linux-2.6/arch/nios2/boards/generic-dts/include/asm/nios.h path... The only boards are 3c120 or neek... I can select device tree support in kernel config but there are any fields "()" to specify the path to my dts file. Have I the right branch? Thank you very much for your help. Best regards. Pierre
