15 years agoQuestion on Git Branches to use [nios2mmu vs unstable-nios2mmu]
Hi everyone I'm currenlty looking into using Linux on the NIOS for my company. Will be getting a DE4 from Terassic shortly but in the meantime I'm doing all the prepwork to understand as much a...
15 years agoHi,
I use the nios2mmu branch because it deals with the custom_fpga.h file instead of the device tree (I work with Windows XP and I don't know if the sopc2dts tool works with Windows). I created a board layer like said here in Altera Wiki (alterawiki.com/wiki/Creating_a_Nios_II_Design_with_an_MMU) I downloaded the toolchain nios2gcc-20080203.tar.bz2 Here is my problem: After having exported the PATH (export PATH=$PATH:~/path_to_toolchain/opt/nios2/bin), when I want to compile the kernel, the simple instruction make dosen't work. Here is the trace: ////////////////////////////////////////////////////////////////////////////////// pierre@ubuntu:~/nios_linux_2010/nios2-linux/uClinux-dist$ CROSS_COMPILE=/home/pierre/nios_compilo/opt/nios2/bin/nios2-linux- make make -f tools/autotools.mk autotools-cache make[1]: entrant dans le répertoire « /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist » set -e; mkdir -p /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/tools/autotools-cache/build//$$; cd /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/tools/autotools-cache/build//$$; gt=`../../create-target-cache.sh nios2-linux-gnu`; cp $gt /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/vendors/config/$gt; touch /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/tools/autotools-cache/build/nios2-linux-gnu ../../create-target-cache.sh: 30: nios2-linux-gnu-gcc: not found ../../create-target-cache.sh: 31: nios2-linux-gnu-gcc: not found Using inc dir for nios2-linux-gnu (nios2-unknown-linux-gnu): ../../create-target-cache.sh: 65: nios2-linux-gnu-gcc: not found xargs: nios2-linux-gnu-readelf: Aucun fichier ou dossier de ce type make[1]: quittant le répertoire « /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist » ln -sf staging-compiler tools/nios2-linux-gnu-gcc ln -sf staging-compiler tools/nios2-linux-gnu-g++ ln -sf staging-compiler tools/nios2-linux-gnu-cpp ln -sf staging-compiler tools/nios2-linux-gnu-ld ln -sf cross-pkg-config tools/nios2-linux-gnu-pkg-config chmod +x tools/romfs-inst.sh tools/modules-alias.sh tools/build-udev-perms.sh . linux-2.6.x/.config; if [ "$CONFIG_INITRAMFS_SOURCE" != "" ]; then mkdir -p `dirname $CONFIG_INITRAMFS_SOURCE`; touch $CONFIG_INITRAMFS_SOURCE || exit 1; fi rm -f linux-2.6.x/usr/initramfs_data.cpio make ARCH=nios2 CROSS_COMPILE=nios2-linux-gnu- O=/home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/linux-2.6.x -j1 -C ../linux-2.6 || exit 1 make[1]: entrant dans le répertoire « /home/pierre/nios_linux_2010/nios2-linux/linux-2.6 » nios2-linux-gnu-gcc: command not found; perhaps you need to fix your PATH? Using /home/pierre/nios_linux_2010/nios2-linux/linux-2.6 as source for kernel GEN /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/linux-2.6.x/Makefile CHK include/linux/version.h CHK include/generated/utsrelease.h CC kernel/bounds.s nios2-linux-gnu-gcc: command not found; perhaps you need to fix your PATH? make[3]: *** [kernel/bounds.s] Erreur 127 make[2]: *** [prepare0] Erreur 2 make[1]: *** [sub-make] Erreur 2 make[1]: quittant le répertoire « /home/pierre/nios_linux_2010/nios2-linux/linux-2.6 » make: *** [linux] Erreur 1 pierre@ubuntu:~/nios_linux_2010/nios2-linux/uClinux-dist$ ////////////////////////////////////////////////////////////////////////////////// I have to add CONFIGURE_HOST=nios2-linux because, without this, the prefix needed is nios2-linux-gnu witch dosen't exists for me. But then, I have this error : ////////////////////////////////////////////////////////////////////////////////// pierre@ubuntu:~/nios_linux_2010/nios2-linux/uClinux-dist$ CROSS_COMPILE=/home/pierre/nios_compilo/opt/nios2/bin/nios2-linux- make CONFIGURE_HOST=/home/pierre/nios_compilo/opt/nios2/bin/nios2-linux- make -f tools/autotools.mk autotools-cache make[1]: entrant dans le répertoire « /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist » set -e; mkdir -p /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/tools/autotools-cache/build//home/pierre/nios_compilo/opt/nios2/bin//$$; cd /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/tools/autotools-cache/build//home/pierre/nios_compilo/opt/nios2/bin//$$; gt=`../../create-target-cache.sh /home/pierre/nios_compilo/opt/nios2/bin/nios2-linux-`; cp $gt /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/vendors/config/$gt; touch /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/tools/autotools-cache/build//home/pierre/nios_compilo/opt/nios2/bin/nios2-linux- /bin/sh: ../../create-target-cache.sh: not found make[1]: *** [/home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/tools/autotools-cache/build//home/pierre/nios_compilo/opt/nios2/bin/nios2-linux-] Erreur 127 make[1]: quittant le répertoire « /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist » make: *** [autotools-cache] Erreur 2 pierre@ubuntu:~/nios_linux_2010/nios2-linux/uClinux-dist$ CROSS_COMPILE=/home/pierre/nios_compilo/opt/nios2/bin/nios2-linux- make CONFIGURE_HOST=nios2-linuxmake -f tools/autotools.mk autotools-cache make[1]: entrant dans le répertoire « /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist » make[1]: Rien à faire pour « autotools-cache ». make[1]: quittant le répertoire « /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist » chmod +x tools/romfs-inst.sh tools/modules-alias.sh tools/build-udev-perms.sh . linux-2.6.x/.config; if [ "$CONFIG_INITRAMFS_SOURCE" != "" ]; then mkdir -p `dirname $CONFIG_INITRAMFS_SOURCE`; touch $CONFIG_INITRAMFS_SOURCE || exit 1; fi rm -f linux-2.6.x/usr/initramfs_data.cpio make ARCH=nios2 CROSS_COMPILE=nios2-linux- O=/home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/linux-2.6.x -j1 -C ../linux-2.6 || exit 1 make[1]: entrant dans le répertoire « /home/pierre/nios_linux_2010/nios2-linux/linux-2.6 » Using /home/pierre/nios_linux_2010/nios2-linux/linux-2.6 as source for kernel GEN /home/pierre/nios_linux_2010/nios2-linux/uClinux-dist/linux-2.6.x/Makefile CHK include/linux/version.h CHK include/generated/utsrelease.h CC kernel/bounds.s nios2-linux-gcc: /include: No such file or directory nios2-linux-gcc: /include: No such file or directory make[3]: *** [kernel/bounds.s] Erreur 1 make[2]: *** [prepare0] Erreur 2 make[1]: *** [sub-make] Erreur 2 make[1]: quittant le répertoire « /home/pierre/nios_linux_2010/nios2-linux/linux-2.6 » make: *** [linux] Erreur 1 ////////////////////////////////////////////////////////////////////////////////// Thank you for your help. Best regards. Pierre
