9 years ago
Question for SPI
Hello! Please tell me how to check the status of the pin MISO.
unsigned long int Get7794_Data(alt_u8 channel)
unsigned long int data;
alt_u8 cfg_reg;
cfg_reg = (channel-1)&0xFF;
spi_select_slave(0x21000,0);
spi_send(0x21000,0x10);
spi_send(0x21000,0x00);
spi_send(0x21000,cfg_reg);
// ????????? DOUT/RDY - the line goes low when a new data-word is available in the output register
spi_send(0x21000,0x58);
data = (unsigned)(spi_send(0x21000,0x58)) << 16;
data |= (unsigned)(spi_send(0x21000,0x58)) << 8;
data |= (unsigned)(spi_send(0x21000,0x00));
spi_deselect_slave(0x21000,0);
return data;
    One way is to add a PIO peripheral with an input connected to the MISO pin and monitor that directly.
    The code you pasted is just showing (normal) byte-wise access of the peripheral so there is no direct way to poll the MISO pin status.
