15 years agoQuartus II with ubuntu 11.04
Hi , I just installed Quartus II on ubuntu 11.04 operating system. It successfully got installed and i can see a directory named altera in my home directory which has further subdirectories. No...
15 years ago --- Quote Start --- Now, i opened Quartus again and reconnected the USB but still i am unable to see the USB blaster in hardware setup. --- Quote End --- Do you have a USB-Blaster plugged into this machine? Is it a real machine or a virtual machine? Virtual machines do not work (at least the latest versions of VMWare and VirtualBox do not). Did you try any of the tests mentioned in the udev rules comments? * lsusb should show you the Altera device * jtagconfig can be used to scan a JTAG chain Cheers, Dave
