APaci1
7 years agoQuartus 18.1 + NiosII F on CyclomV : boot fails!
Hello to everyone ! I have my hardware with Cyclone V 5CSEBA4 , Quartus 18.1 standard licensed. I make a QSYS with an EPCQ64 controller and NiosIIF and I develop my application with Eclipse. It ru...
- 7 years ago
Hello sir,
Kindly check the following items:
1- Make sure you use a clock source to Serial Flash controller IP (EPCQ) up to 25MHz (MAX).
2- Make sure your Nios II is running at 50MHz.
3- Make sure the MSEL is pointing to the correct flash configuration:
If using QUAD, MSEL should be 10010
If using STANDARD, MSEL should be 10011
Please let me know if this could help you.
APaci1
7 years ago->When I select reset vector to ecpq address, I cannot debug Nios with Jtag, but I think this is normal.. to debug it, I need to restore reset vector to original OCRAM.. so boot is not debuggable anyway...
->I checked the epcq_controller2_0.hex, obviously it is very little in size,
about 56k... my onchip ram is 200k so the problem is not here....
