9 years agoQSPI Flash Programming
Hello All, I am trying to follow the GSRD for booting from flash here: https://rocketboards.org/foswiki/documentation/a10gsrd161qspiboot I am using the precompiled binaries as there were m...
9 years agoHi,
I had the same deadlock. I programmed a wrong QSPI image then the U-Boot gets stuck and HPS flash programmer could not access it anymore. What I did is: Remove the QSPI card and power on the system. While the system is running plug on the QSPI card (ensure not to make any short circuits!!). This will ensure that u-boot is not running and the card has power. Then erase the card with quartus_hps. Regards MillerTheRipper EDIT: I found a much better smooth way to do prevent the HPS from booting. Try: quartus_hps --boot=18 --cable=1 --operation=pv uboot_w_dtb-mkpimage.bin
