14 years agoQ:Maybe git-pull is broken?
http://www.alterawiki.com/wiki/dasuboot
Or if you installed from the nios2-linux tarball as InstallNios2Linux, cd nios2-linux/toolchain-build git pull origin cd nios2-linux/u-boot git fetch origin git checkout -b my_nios2 origin/master ====================================================== When I input the command "git pull origin" in the nios2-linux/toolchain-build folder like this:
# git pull origin
/usr/local/libexec/git-core/git-pull: line 282: exec: git-merge: not found
fatal: 'pull' appears to be a git command, but we were not
able to execute it. Maybe git-pull is broken?
What's wrong with it ? THX!!!!!!1 Reply
http://www.alterawiki.com/wiki/install_nios_ii_linux
Toolchain We will proceed to build the toolchain. If you don't want or fail to build it yourself, you may use the prebuild BinaryToolchain. If you work on x86_64, 64 bits platform, you will need to change the arch to 32 bits , with "setarch i386" , to build gcc. cd toolchain-build gcc --version git clean -f -x -d # clean on restart make gcc elf2flt gdb-host ============================================== I do it above,but
Is it right ? Thanks !checking for nl_langinfo and CODESET... yes checking configuration for building shared libraries... supported updating cache ./config.cache configure: creating ./config.status config.status: creating Makefile config.status: creating doc/Makefile config.status: creating examples/Makefile config.status: creating shlib/Makefile config.status: creating config.h config.status: executing default commands make: Entering directory `/home/nios2-linux/toolchain-build/build/gdb-host/readline' rm -f readline.o gcc -c -DHAVE_CONFIG_H /home/nios2-linux/toolchain-build/build/nios2/bin/nios2-elf-gcc- -I. -I/home/nios2-linux/toolchain-build/../insight/readline -DRL_LIBRARY_VERSION='"5.1"' -g -O2 /home/nios2-linux/toolchain-build/../insight/readline/readline.c gcc: /home/nios2-linux/toolchain-build/build/nios2/bin/nios2-elf-gcc-: No such file or directory make: *** Error 1 make: Leaving directory `/home/nios2-linux/toolchain-build/build/gdb-host/readline' make: *** Error 2 make: Leaving directory `/home/nios2-linux/toolchain-build/build/gdb-host' make: *** Error 2 make: Leaving directory `/home/nios2-linux/toolchain-build/build/gdb-host' make: *** Error 2 #
