15 years agoPush Buttons Adujusting Speed
So I'm using a DE2 board with NIOS and Quartus 9.1 and I'm trying to make a function to adjust the speed of packets sent over Ethernet as a modification of the DE2_NET sample. the problem is that whenever I try to implement push buttons in NIOS it both slows down the packet transmission considerably and doesn't display my test case. right now I have this (Not all the code, just the pertinent section, below it is all the code):
while (1)
bool buttonPressed;
delayAmount = handle_key(&buttonPressed);
// delay = delay + delayAmount;
Randdata(); //Software randomness causes a 1/3 loss in speed
// if(delayAmount !=0)
// msleep(delay);
TransmitPacket(SND,flenght); // Send repetitively 1468 bytes of data.
times++;
IOWR(SEG7_DISPLAY_BASE, 0, times); // Show in hex digits the# of packets sent.
return 0;
int handle_key(bool *pButtonPressed){
bool bSpeedDown, bSpeedUp, bMode;
*pButtonPressed = FALSE;
# ifdef ENABLE_DEBOUNCE
static alt_u32 next_active_time = 0;
if (alt_nticks() < next_active_time ){
return;
next_active_time = alt_nticks();# endif
//alt_u8 *button;
volatile int* button;
//button = IORD_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE);
*button = IORD_ALTERA_AVALON_PIO_DATA(BUTTON_PIO_BASE);
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0); // clear flag
IOWR_ALTERA_AVALON_PIO_DATA(LED_RED_BASE, *button);
bSpeedDown = (*button & 0x08)?TRUE:FALSE;
bSpeedUp = (*button & 0x04)?TRUE:FALSE;
bMode = (*button & 0x02)?TRUE:FALSE;
if(bSpeedDown || bSpeedUp || bMode){ // This if statement introduced a 3 Mbit/s hit in performance
LCD_Test2();
/* if (bSpeedDown){
LCD_Test2();
else if (bSpeedUp){
LCD_Test2();
else{
LCD_Test2();
if (bSpeedDown || bSpeedUp || bMode){
next_active_time += alt_ticks_per_second()/5; // debounce
} # endif
return 0;
} # include "alt_types.h" // alt_u32# include "altera_avalon_pio_regs.h" //IOWR_ALTERA_AVALON_PIO_DATA# include "sys/alt_irq.h" // interrupt# include <stddef.h># include "sys/alt_flash.h"# include "sys/alt_flash_types.h"# include "sys/alt_alarm.h" // time tick function (alt_nticks(), alt_ticks_per_second())# include "sys/alt_timestamp.h" # include "sys/alt_stdio.h"# include <fcntl.h>
# include <io.h># include <stdio.h># include <unistd.h># include <stdlib.h># include <string.h>
# include "LCD.h"# include "system.h"# include "DM9000A.C"# include "hello_led.h"# include "test.h"
unsigned int aaa,rx_len,i,packet_num, times, counter;
unsigned char RXT;
unsigned char SND; // Payload buffer
unsigned int IPsource_1,IPsource_2,IPsource_3,IPsource_4;
unsigned int IPdestination_1,IPdestination_2,IPdestination_3,IPdestination_4;
unsigned int IPchecksum1,IPchecksum2,IPchecksum3,IPchecksum4,IPchecksum5;
unsigned int Mac_source1, Mac_source2, Mac_source3, Mac_source4, Mac_source5, Mac_source6;
unsigned int Mac_dest1, Mac_dest2, Mac_dest3, Mac_dest4, Mac_dest5, Mac_dest6;
unsigned int times, lenght_h, lenght_l;
unsigned int flenght, IPlenght_h, IPlenght_l, data_lenght, IPlenght;
int delay, delayAmount;
int main(void)
IPsource_1 = 0xC0; // Assign ie: 192.168.0.44 IP for the DE2
IPsource_2 = 0xA8;
IPsource_3 = 0x00;
IPsource_4 = 0x2C;
IPdestination_1 = 0xC0; // Insert your IP data here
IPdestination_2 = 0x11;
IPdestination_3 = 0xA7;
IPdestination_4 = 0xD9;
Mac_dest1 = 0x00; // Insert your MAC address data here
Mac_dest2 = 0x03;
Mac_dest3 = 0x25;
Mac_dest4 = 0x43;
Mac_dest5 = 0x6A;
Mac_dest6 = 0x27;
Mac_source1 = 0x01; // Assign a MAC address for DE2
Mac_source2 = 0x60;
Mac_source3 = 0x6E;
Mac_source4 = 0x11;
Mac_source5 = 0x02;
Mac_source6 = 0x0F;
delay = 0;
data_lenght = 1468; // Maximun Data lenght 1468 bytes
flenght = data_lenght + 0x2E; //Total packet lenght
lenght_h = ((data_lenght+8) & 0xFF00)>>8; // Convert in H byte and L byte
lenght_l = ((data_lenght+8) & 0x00FF);
IPlenght = data_lenght + 8 + 20; // IP Lenght for IP header
IPlenght_h = (IPlenght & 0xFF00)>>8; // Convert in H byte and L byte
IPlenght_l = (IPlenght & 0x00FF);
// Calculating the IP checksum
IPchecksum1 = 0x0000C511 + (IPsource_1<<8)+IPsource_2+(IPsource_3<<8)+IPsource_4+
(IPdestination_1<<8)+IPdestination_2+(IPdestination_3<<8)+(IPdestination_4)+
(IPlenght_h<<8) + IPlenght_l;
IPchecksum2 = ((IPchecksum1&0x0000FFFF)+(IPchecksum1>>16));
IPchecksum3 = 0x0000FFFF - IPchecksum2;
IPchecksum4 = (IPchecksum3 & 0xFF00)>>8;
IPchecksum5 = (IPchecksum3 & 0x00FF);
srand ( time(NULL) );
unsigned char TXT = { Mac_dest1, Mac_dest2, Mac_dest3, Mac_dest4 ,Mac_dest5, Mac_dest6,
Mac_source1, Mac_source2, Mac_source3, Mac_source4, Mac_source5, Mac_source6,
0x08, 0x00, 0x45, 0x00, IPlenght_h, IPlenght_l,
0x00, 0x00, 0x00, 0x00, 0x80, 0x11,
IPchecksum4, IPchecksum5, IPsource_1, IPsource_2, IPsource_3, IPsource_4,
IPdestination_1, IPdestination_2, IPdestination_3, IPdestination_4, 0x04, 0x00,
0x04, 0x00, lenght_h, lenght_l, 0x00, 0x00};
for (i = 0; i < 42; i++) // Load the TXT in the SND (ethernet packet).
SND = TXT;
for (i = 42; i < flenght-4; i++) // generating the data to send.
SND = i-42;
SND = 0x35; // This checksum is not correct, but also the net recieve the packets correctly.
SND = 0x15; // To do, calculate checksum.
SND = 0xF0;
SND = 0x13;
LCD_Test();
DM9000_init(); // Initialize the DM9000A.
handle_button_interrupts();
init_button_irq();
basic_test();
//Add ability to change data rates
//Modes, send out data at 34 Mbit/s, send data out in bursts, storing in RAM until full
//How to get MAC/IP of other INK Board/s and hard code in or software get
while (1)
bool buttonPressed;
// msleep(delay);
times++;
return 0;
//------------------Helper Functions---------------------------------------
//Generates random data to be sent via Ethernet packets
//Every time a new packet is sent new data is generated
//Slows down transmission, in tests went from 34 Mbit/s to 24 Mbit/s
void Randdata(){
//Random Data Generated
SND = rand() % 255; SND = rand() % 255; SND = rand() % 255;
//Handles Button presses
return;
//alt_u8 *button;
LCD_Test2();
/* if (bSpeedDown){
LCD_Test2();
else if (bSpeedUp){
LCD_Test2();
else{
LCD_Test2();
} # endif
return 0;
Whenever I press KEY3-KEY1 the respective red LED goes dark as it should, but the LCD TEST2 case does not display. Can anyone help me out here?1 Reply
I think this is a problem:
volatile int* button; *button = IORD_ALTERA_AVALON_PIO_DATA(BUTTON_PIO_BASE); You are using an uninitialized pointer which will corrupt memory somewhere. The correct code is the one you commented out (but you need to define alt_u8 button, not alt_u8 *button). Moreover, IMHO it was correct to test button switching edge instead of button status. Now you always have delay=delayAmount=0 and whenever you press a button the function will keep on retriggering until you release it.
