15 years agopurpuse of waitrequest
Hello I've designed a custom component which acts as an Avalon Slave. This component has a 32-bit result-register. If data are valid or not is indicated by Bit 31 (true (1) = data valid). Now I...
15 years agoThank you for your help.
After studing the avalon specification again I have a few question more. 1) Is it correct that a "normal" read or write-access needs two cycles? 2) Can I simulate the read and write behaviour with ModelSim? Is there a master aviable? Thank you brunjak
