8 years agoprovided SPL prevents Linux from booting
Hello all, I'm attempting to do some work at the SPL/U-Boot level, and am finding that when replacing the SPL preloader, it boots U-Boot OK, but when U-Boot passes control to zImage, it hangs. ...
8 years agoCan you show the console output from the original (good) boot up to the point where it says "Starting kernel". I'm wondering if there is a difference in your clock settings, or in your device tree blob. Can you double check to make sure you are using the same DTB file in both cases?
